omnistudio-developer question 39 discussion
View all Certified OmniStudio Developer here
back to salesforce forum
Question 39
A developer need to configure a calculation procedure to calculation a subtotal using two different
depending on whether the input Boolean variable is Customer is set to true or false.
How should a developer configure the calculation procedure to conditionally execute the correct
formula?
  • A. Use two separate Calculation Steps with the Conditional Step property selected: use the ISTRUE(isCustomer) and NOT (ISTRUE) (isCustomer) functions in the Condition syntax.
  • B. Use two separate Calculation Steps with the Conditional Step property selected: reference just the isCustomer variable in the Conditional syntax (no comparison necessary)
  • C. Use two separate Calculation Steps with the Conditional Step property selected: compare the isCustomer variable directly to the literal true and false values in the Condition syntax.
  • D. Use a single Calculation Steps with IF statement directly in the formula definition to reference the isCustome variable and conditionally perform the appropriate calculation.
sfbaby
1 year, 7 months ago
I think the answer should be C
