pcnsa question 193 discussion
View all Palo Alto Networks Certified Network Security Administrator here
back to palo-alto-networks forum
Question 193
An administrator manages a network with 300 addresses that require translation. The administrator configured NAT with an address pool of 240 addresses and found that connections from addresses that needed new translations were being dropped.
Which type of NAT was configured?
  • A. Dynamic IP
  • B. Static IP
  • C. Dynamic IP and Port
  • D. Destination NAT
sara123
8 months ago
The size of the NAT pool
should be equal to the number of internal hosts that require address translations. By default,
if the source address pool is larger than the NAT address pool and eventually all of the NAT
addresses are allocated, new connections that need address translation are dropped. To
override this default behavior, use Advanced (Dynamic IP/Port Fallback) to enable the use
of DIPP addresses when necessary
