ns0-593 question 9 discussion
You have a 4-node NetApp ONTAP 9.8 cluster with an AFF A400 HA pair and a FAS8300 HA pair with
16 TB NL-SAS drives. You are asked to automatically tier 150 TB of Snapshot copy data from the AFF
A400 aggregates to the FAS8300.
In this scenario, which ONTAP license must be added to the cluster to accomplish this task?
  • A. S3 license
  • B. VE license
  • C. TPM license
  • D. FabricPool license
Dinker
7 months, 2 weeks ago
https://docs.netapp.com/us-en/ontap/fabricpool/local-bucket-tier-data-task.html
To automatically tier 150 TB of Snapshot copy data from the AFF A400 aggregates to the FAS8300 in your NetApp ONTAP 9.8 cluster, you need to add the following ONTAP license:
FabricPool is a data tiering technology in ONTAP that allows you to automatically tier cold data from high-performance SSD aggregates to lower-cost storage, such as NL-SAS drives in your FAS8300.
Sources:
- https://docs.netapp.com/us-en/ontap/fabricpool/fp_configure.html
- https://docs.netapp.com/us-en/ontap/fabricpool/fp_overview.html
