ns0-593 question 8 discussion
A storage administrator reports that a monitoring toot is reporting that the storage controller reads
between 90% to 93% CPU use. You run the sysstat -m command against the node in question.
  • A. The customer should be advised to exclude certain workflows to reduce use.
  • B. High network exempt use could be a problem.
  • C. You should immediately investigate further by gathering perfstat data and opening a support case.
  • D. The CPU Is not a first-order monitoring metric for ONTAP.
I agree with investigate with Support
