ns0-593 question 57 discussion
Question 57
A customer wants to connect a NetApp AFF A700 system to a 40GbE switch. The controllers have a
10/40G Ethernet card in slot 4 for this purpose. The link comes up fine on node 2, but it will not come
up on node 1. You look at the AutoSupport data for the nodes in question and see the output shown
in the exhibit.
What is the cause of the customer's problem?
  • A. The cable is plugged in upside down.
  • B. The incorrect cable is used.
  • C. The ports are configured for 4x10Gbit instead of 40Gbit.
  • D. The port has an incorrect SFP inserted.
Dinker
9 months, 1 week ago
Answer is C
https://kb.netapp.com/on-prem/ontap/OHW/OHW-KBs/Convert_Ethernet_port_between_40GbE_and_4x10GbE_personality
