ns0-593 question 4 discussion
You have a customer who is concerned with high CPU and disk utilization on their SnapMirror
destination system. They are worried about high CPU and disk usage without any user operations.
In this situation, what should you tell the customer?
  • A. Suggest that the customer manually cancel any scanners on the destination to reduce CPU usage.
  • B. Explain that background tasks such as SnapMirror throttle up in the absence of user workload.
  • C. Suggest that the customer throttle their SnapMirror relationships to reduce resource consumption.
  • D. Explain that only user workload should use the CPU and Investigate further.
Dinker
10 months, 2 weeks ago
https://kb.netapp.com/on-prem/ontap/Perf/Perf-KBs/High_CPU_utilization_on_a_Snapmirror_Destination_Node
3 months, 4 weeks ago
In this situation, you should tell the customer:
When there is no active user workload, background tasks like SnapMirror can utilize more CPU and disk resources to complete their operations more efficiently. This can result in higher CPU and disk utilization on the SnapMirror destination system even without user operations.
Sources:
- https://docs.netapp.com/us-en/ontap-cli/snapmirror-show.html
- https://docs.netapp.com/us-en/ontap-cli/snapmirror-policy-create.html
