ns0-593 question 38 discussion
Question 38
Your customer noticed in NetApp Active IQ that their NetApp Cloud Volumes ONTAP for Azure HA
solution is no longer sending AutoSupport messages over HTTPS. A support ticket has been opened
to find out why. No changes have been made to the Cloud Volumes ONTAP for Azure HA
environment.
In this scenario, which two autosupport command parameters should be used to validate that
AutoSupport Is working properly? {Choose two.)
  • A. -mail-hosts
  • B. -transport
  • C. -proxy-url
  • D. -to
Dinker
7 months, 1 week ago
= The -transport parameter specifies the protocol used to send AutoSupport messages, which should be HTTPS by default. The -proxy-url parameter specifies the proxy server used to sendAutoSupport messages, which should be the Connector’s IP address and port if the Cloud Volumes ONTAP nodes do not have outbound internet access. These two parameters can be used to check the AutoSupport configuration and connectivity status.
https://docs.netapp.com/us-en/ontap/system-admin/troubleshoot-autosupport-https-task.html
