Which two throughput elements are controlled by host applications? (Choose two.)
operation size
Jitter
concurrency
latency
1 month ago
The two throughput elements controlled by host applications are:
1. Concurrency: This refers to the number of simultaneous operations or threads that the host applications can handle. Concurrency can directly impact the throughput by determining how many operations can be processed in parallel.
2. Operation Size: This refers to the size of the data blocks that the host applications read from or write to the storage. Larger operation sizes can increase throughput by transferring more data per operation, while smaller operation sizes can result in higher IOPS but potentially lower throughput.
Want to join our community?
