ns0-593 question 33 discussion
Question 33
A system panic due to an "L2 watchdog timeout hard reset" error occurred. You have found a FIFO
message in the SP log.
Which FIFO message Is useful for Investigating this Issue?
  • A. before NMI BBSP:C=00 L=00 FIFO: F3 F2 F1 F0 5 B2 0 0 0 80 20 E F E3 C0 C2 3 4 6 7 9 9 A
  • B. BIOS exit BBSP:C=2F L=20 FIFO: 2 C8 C9 C4 24 4 6 18 7 8 11
  • C. before Reset BBSP:C=00 L=00 FIFO:
  • D. ONTAP Shutdown BBSP:C=00 L=2F FIFO:
To investigate the "L2 watchdog timeout hard reset" system panic and the related FIFO message in the SP log, the most useful FIFO message would be:
This FIFO message indicates the state of the system just before the reset occurred, which is crucial for understanding the conditions that led to the watchdog timeout and subsequent hard reset.
Sources:
- https://docs.netapp.com/us-en/ontap/system-admin/sp-sensor-status-values-command-output-concept.html
- https://docs.netapp.com/us-en/ontap-ems/callhome-reboot-events.html
- https://docs.netapp.com/us-en/ontap/system-admin/sp-concept.html
