ns0-593 question 32 discussion
Question 32
After a normal power down of both nodes for building maintenance, Node01 of a 2-node cluster
cannot be powered back up; however, all disk shelves are powered.
Which action should be performed to bring the cluster online and allow Node02 to serve data?
  • A. Recreate the cluster with the system configuration recovery cluster recreate -from node command.
  • B. Reboot the node With the system node reboot -node Node02 -bypass-optimization true command.
  • C. Perform a takeover with the storage failover takeover -ofnode Node01 -option force command.
  • D. Reinitialize the cluster with option 4a from the boot menu.
The correct action to bring the cluster online and allow Node02 to serve data when Node01 cannot be powered back up is:
This command forces Node02 to take over the storage and services of Node01, allowing the cluster to continue serving data despite Node01 being down.
Sources:
- https://docs.netapp.com/us-en/ontap/high-availability/halt-reboot-node-wo-takeover-task.html
