ns0-593 question 30 discussion
Question 30
After users start reporting the Inability to create new flies in a CIFS share, you find EMS events for
wafl.dir.size.max logged for the volume of the SVM to which the share points.
In this scenario, which action should you take to solve this issue?
  • A. Delete unneeded files from the directory.
  • B. Move the volume to a different aggregate.
  • C. Increase the maximum number of files for the volume.
  • D. Increase the maximum directory size for the volume.
Dinker
10 months ago
Dinker
9 months, 4 weeks ago
3 months, 2 weeks ago
In this scenario, to solve the issue of users being unable to create new files in a CIFS share due to the wafl.dir.size.max event, you should:
This action will allow the directory to accommodate more files and resolve the issue.
Sources:
- https://docs.netapp.com/us-en/ontap/smb-hyper-v-sql/create-continuously-available-shares-task.html
- https://docs.netapp.com/us-en/ontap/smb-admin/create-share-force-group-setting-task.html
- https://docs.netapp.com/us-en/ontap/smb-admin/configure-offline-files-support-task.html
