ns0-593 question 27 discussion
Question 27
A customer's storage administrator Informs you about the deactivated Automatic Switchover (AUSO)
feature on their MetroCluster IP environment.
What Information would you tell your customer in this scenario?
  • A. The AUSO feature cannot be activated due to a non-mirrored aggregate.
  • B. The AUSO feature is not available in Metrocluster IP installations by design.
  • C. A faulty link automatically deactivated the AUSO feature.
  • D. This is a configuration failure, you can activate that feature for the customer.
Dinker
7 months, 1 week ago
https://docs.netapp.com/us-en/ontap-metrocluster/manage/concept_understanding_mcc_data_protection_and_disaster_recovery.html#types-of-disasters-and-recovery-methods
In this scenario, you should inform your customer that:
The AUSO (Automatic Unplanned Switchover) feature requires certain conditions to be met, including having mirrored aggregates. If any aggregate is not mirrored, the AUSO feature will be deactivated.
Sources:
- https://docs.netapp.com/us-en/ontap/revert/task_disable_asuo.html
- https://docs.netapp.com/us-en/ontap/revert/task_enabling_automatic_switchover_for_metrocluster_configurations.html
- https://docs.netapp.com/us-en/ontap-metrocluster/maintain/task_power_off_an_entire_mcc_ip_configuration.html
