ns0-593 question 25 discussion
Question 25
You Just used the CLI to create a NetApp ONTAP FlexGroup Volume on a NetApp Cloud Volumes
ONTAP instance. After creation, you notice odd behavior in NetApp Cloud Manager.
In this scenario, what Is the reason for this behavior?
  • A. Cloud Volumes ONTAP does not support FlexGroup volumes.
  • B. The Capacity Management Mode within Cloud Manager should be set to Manual.
  • C. The Capacity Management Mode within Cloud Manager should be set to Automatic.
  • D. Cloud Manager must be used to provision the FlexGroup volume.
0%
0%
Dinker
8 months ago
https://kb.netapp.com/Cloud/BlueXP/Cloud_Manager/FlexGroups_in_Cloud_Volumes_ONTAP_QandA
Dinker
8 months ago
1 month, 3 weeks ago
The reason for the odd behavior in NetApp Cloud Manager after using the CLI to create a NetApp ONTAP FlexGroup Volume on a NetApp Cloud Volumes ONTAP instance is:
NetApp Cloud Manager is designed to manage and provision FlexGroup volumes in a Cloud Volumes ONTAP environment. Using the CLI to create the FlexGroup volume can lead to inconsistencies and unexpected behavior in Cloud Manager.
Sources:
- https://docs.netapp.com/us-en/ontap/flexgroup/convert-flexvol-volume-task.html
- https://docs.netapp.com/us-en/ontap/flexgroup/creation-workflow-task.html
- https://docs.netapp.com/us-en/ontap/flexgroup/protect-snapshot-copies-task.html
