ns0-593 question 20 discussion
Question 20
You created a new NetApp ONTAP FlexGroup volume spanning six nodes and 12 aggregates with a
total size of 4 TB. You added millions of files to the FlexGroup volume with a flat directory structure
totaling 2 TB, and you receive an out of apace error message on your host.
What would cause this error?
  • A. The maximum number of volume constituents has been reached in the ONTAP software.
  • B. All constituent volumes are full.
  • C. The inode limit is exceeded in the ONTAP software.
  • D. The maxdirsize Is exceeded in the ONTAP software.
0%
0%
Dinker
7 months, 4 weeks ago
1 month, 2 weeks ago
The cause of the "out of space" error message on your host is:
Even though the FlexGroup volume has available space, the inode limit (maximum number of files) might have been reached, causing the "out of space" error. This can happen especially when adding millions of files to a volume.
Sources:
- https://docs.netapp.com/us-en/ontap/flexgroup/monitor-space-usage-task.html
- https://docs.netapp.com/us-en/ontap/flexgroup/configure-automatic-grow-shrink-task.html
