ns0-593 question 2 discussion
Recently, a CIFS SVM was deployed and is working. The customer wants to use the Dynamic DNS
(DDNS) capability available in NetApp ONTAP to easily advertise both data UFs to their clients.
Currently. DNS is only responding with one data LIF. DDNS is enabled on the domain controllers.
Referring to the exhibit, which two actions should be performed to enable DDNS updates to work?
  • A. Disable the -vserver-fqdn parameter for the SVM DDNS services.
  • B. Remove the NFS protocol from the cifs_01 data LIF.
  • C. Enable the -use-secure parameter for the SVM DDNS services.
  • D. Enable the -is-enabled parameter for the SVM DDNS services
0%
0%
Dinker
8 months, 2 weeks ago
https://kb.netapp.com/on-prem/ontap/Ontap_OS/OS-KBs/Configured_DNS_Dynamic-Update_FQDN_does_not_get_used_for_CIFS_server
1 month, 4 weeks ago
To enable DDNS updates to work for the CIFS SVM, you should perform the following actions:
D. Enable the -is-enabled parameter for the SVM DDNS services.
These actions ensure that DDNS is enabled and configured to use secure updates, which are necessary for proper DDNS functionality with Active Directory-integrated DNS servers.
Sources:
- https://docs.netapp.com/us-en/ontap/networking/configure_dns_services_auto.html
- https://docs.netapp.com/us-en/ontap/networking/configure_dynamic_dns_services.html
