ns0-593 question 19 discussion
Question 19
You are deploying NetApp ONTAP Select. When trying to add VMware vCenter to the inventory, you
receive the message shown below.
Credential authentication failed for x.x.x.x with: HostConnectionFailed
In this scenario, how would you correct this problem?
  • A. Change the vCenter password.
  • B. Change the IP address of the ONTAP Select Deploy VM.
  • C. Change the gateway address of the ONTAP Select Deploy VM.
  • D. Change the IP address of the vCenter server.
Dinker
7 months, 2 weeks ago
https://kb.netapp.com/on-prem/ontap/ontap-select/Select-KBs/Credential_authentication_failed_with__HostConnectionFailed
Dinker
To correct the problem of receiving the "Credential authentication failed for x.x.x.x with: HostConnectionFailed" message when trying to add VMware vCenter to the inventory in NetApp ONTAP Select, you should:
The "Credential authentication failed" error indicates that the credentials provided for the vCenter server are incorrect. Changing the vCenter password to the correct one should resolve this issue.
