ns0-593 question 16 discussion
Question 16
You recently discovered the error message shown below in your ONTAP logs.
What should be your first action to correct this Issue?
  • A. Power cycle all the disk storage shelves that contain drives of the aggregate with the my_data_vol volume.
  • B. Determine the root cause behind the inconsistency before attempting any recovery procedure.
  • C. Use the storage takeover command on the storage controller that contains my_data_vol.
  • D. Use the wafliron command against my_data_vol to solve the inconsistency on the volume.
In this scenario, the first action to take to correct the issue indicated by the error message "wafl.incons.userdata.vol:error WAFL inconsistent: volume my_data_vol" should be:
Before attempting any recovery procedures, it is crucial to understand the root cause of the inconsistency. This may involve examining the logs, understanding the sequence of events leading to the error, and consulting with NetApp technical support if necessary. This approach ensures that any corrective actions taken are appropriate and do not inadvertently cause further issues.
Sources:
- https://docs.netapp.com/us-en/ontap-ems/wafl-incons-events.html
- https://docs.netapp.com/us-en/ontap-ems/callhome-wafl-events.html
