ns0-593 question 12 discussion
You have a NetApp ONTAP cluster consisting of four NetApp FAS8200 controllers with two NetApp
CN1610 cluster switches running ONIAP 9.8 software. You are receiving several alert messages
stating that the cluster network has degraded. After troubleshooting, you determine that the errors
are being generated from Node 2, interface e0b.
In this scenario, what should you do first to solve this problem?
  • A. Replace the Twinax cable between Node 2, Interface e0b. and the NetApp CN1610 switch.
  • B. Replace the motherboard on Node 2.
  • C. Replace both NetApp CN1610 switches.
  • D. Replace the NetApp CN1610 switch that connects to Node 2, interface e0b.
Dinker
10 months ago
3 months, 2 weeks ago
First try to replace Twinax cable between Node 2, Interface e0b. and the NetApp CN1610 switch...
