ns0-593 question 10 discussion
Your customer Informs you about SnapMlrror problems after upgrading NetApp ONTAP software to a
newer version. After investigating the event logs and the SnapMirror history, you see information
about delayed updates of the SnapMirror relationships.
How would your customer prevent such problems in the future?
  • A. Quiesce the SnapMirror relationships before upgrading the ONTAP software.
  • B. Verify that the cabling of the hardware port that Is responsible for SnapMirror transfers Is correct.
  • C. Modify the schedules of the SnapMirror relationships after upgrading the ONTAP software.
  • D. Delete the SnapMirror relationships and create them new after upgrading the ONTAP software.
Dinker
10 months, 1 week ago
https://kb.netapp.com/on-prem/ontap/DP/SnapMirror/SnapMirror-KBs/ONTAP_upgrade_triggers_SnapMirror_DelayedUpdate
Dinker
3 months, 3 weeks ago
To prevent SnapMirror problems after upgrading NetApp ONTAP software in the future, your customer should:
Quiescing the SnapMirror relationships ensures that there are no active data transfers during the upgrade process, reducing the risk of encountering issues with SnapMirror after the upgrade.
Sources:
- https://docs.netapp.com/us-en/ontap-7mode-transition/snapmirror/reference_troubleshooting.html
- https://docs.netapp.com/us-en/ontap/snapmirror-active-sync/upgrade-revert-task.html
