ns0-527 question 69 discussion
View all NetApp Certified Implementation Engineer - Data Protection Exam here
Question 69
A customer has a 2-node ONTAP Select HA cluster deployed on the same site. The ONTAP Deploy VM
has been accidentally deleted. The 2-node ONTAP Select HA cluster is still serving data, but the
storage failover capability has been disabled.
In this scenario, what would you do to reestablish the storage failover capability on your cluster?
  • A. Deploy two ONTAP Deploy VMs and a new 2-node ONTAP Select cluster and then migrate the data.
  • B. Deploy a secondary ONTAP Deploy VM and restore the 2-node cluster quorum.
  • C. Deploy two single-node ONTAP Select clusters and migrate all exiting data.
  • D. Deploy a new 4-node ONTAP Select cluster and distribute data from the existing cluster.
Guss
1 year, 4 months ago
No it's B
