ns0-527 question 3 discussion
View all NetApp Certified Implementation Engineer - Data Protection Exam here
You are the administrator of your company's ONTAP clusters. You are asked to provide a disaster
recovery solution between your primary AFF A400 cluster and your FAS2720 cluster with the highest
possible availability at the lowest possible price.
In this scenario, which product will satisfy this requirement?
  • A. MetroCluster
  • B. SM-S
  • C. SnapMirror
  • D. SVM-DR
https://blog.netapp.com/disaster-recovery-solution-for-enterprise-apps/
Guss
1 year, 3 months ago
No, A is not possible, 2 different platform. C seems to be good
