You decide to enable SnapMirror network compression on your NetApp clustered Data ONTAP environment. Which two statements are correct about enabling this feature? (Choose two.)
The data is compressed only while it traverses the network.
The data transfer between the clusters must use the NDMP protocol.
You may only enable SnapMirror network compression on one HA pair in a cluster, and traffic 1-1 is limited to routing through those nodes.
The compression engine creates multiple transfer threads corresponding to the number of CPUs on the source storage system.
AD
0%
0%
Guss
1 year, 5 months ago
Good answers
Want to join our community?
Good answers
