ns0-527 question 139 discussion
View all NetApp Certified Implementation Engineer - Data Protection Exam here
Question 139
You are asked to provide a solution that will allow a client to copy the data stored in a FlexVol volume
to a remote tape system for archiving. You are using a cluster-aware backup application to perform
this task.
Which three actions are required when you configure this solution for your client? (Choose three.)
  • A. Configure NDMP at the SVM level.
  • B. Configure multiple LIFs for SVM-scoped NDMP.
  • C. Configure NDMP at the node level.
  • D. Create a backup user account on the cluster.
  • E. Configure a LIF for node-scoped NDMP.
C,D,E
Guss
1 year, 7 months ago
That's wrong, correct ones are : A, D, B if needed
