ns0-194 question 49 discussion
View all NetApp Certified Support Engineer Exam here
Question 49
A customer ordered a FAS2720 cluster with 8 TB SATA drives. The customer wants to use the
Advanced
Drive Partitioning (ADP) feature to avoid consuming the high capacity drives for the root aggregate.
Before you use the cluster setup, you issue the aggr status command and notice that ADP is not being
used.
In this scenario, what would you use to implement ADP?
  • A. loader prompt
  • B. special boot menu
  • C. nodeshell
  • D. SP prompt
semwe
9 months, 2 weeks ago
special boot menu for boot options
