mcd-level-1 question 91 discussion
back to mulesoft forum
Question 91
Refer to the exhibits. The Set Payload transformer in the addltem child flow uses DataWeave to
create an order object.
What is the correct DataWeave code for the Set Payload transformer in the createOrder flow to use
the addltem child flow to add a router call with the price of 100 to the order?
  • A. lookup( "addltern", { price: "100", item: "router", itemType: "cable" } )
  • B. addltem( { payload: { price: "100", item: "router", itemType: "cable" > } )
  • C. lookup( "addltem", { payload: { price: "100", item: "router", itemType: "cable" } > )
  • D. addltem( { price: "100", item: "router", itemType: "cable" } )
sachudixit
1 year, 8 months ago
A is correct
galibakravan (replied to sachudixit)
10 months, 2 weeks ago
Correct. A is the right answer
