mcd-level-1 question 208 discussion
back to mulesoft forum
Question 208
An API instance of type API endpoint with API proxy is created in API manager using an API
specification from Anypoint Exchange. The API instance is also configured with an API proxy that is
deployed and running in CloudHub.
An SLA- based policy is enabled in API manager for this API instance.
Where can an external API consumer obtain a valid client ID and client secret to successfully send
requests to the API proxy?
In the organization's public API portal in Anypoint Exchange, from an approved client application for
the API proxy
In Anypoint Studio, from components generated by APIkit for the API specification
In Anypoint Studio, from components generated by Rest Connect for API specification
In Runtime Manager, from the properties tab of the deployed approved API proxy
* When a client application is registered in Anypoint Platform, a pair of credentials consisting of a
client ID and client secret is generated.
* When the client application requests access to an API, a contract is created between the
application and that API.
* An API that is protected with a Client ID Enforcement policy is accessible only to applications that
have an approved contract.
Correct Answer: In the organization's public API portal in Anypoint Exchange, from
Explanation:an approved client application for the API proxy
https://docs.mulesoft.com/api-manager/2.x/client-id-based-policies
d.abbas
1 year, 1 month ago
A is correct
acwork
1 year ago
