mcd-level-1 question 204 discussion
back to mulesoft forum
Question 204
Refer to the exhibits. APIKit router is used to generate the flow components for RAML specification.
The Mule application must be available to REST clients using the two URL's
http://localhost:8081/internal
and
http://localhost:8081/external
How many APIKit Router components are generated to handle requests to every endpoint defined in
RAML specification?
1.
Library.raml
2.
/books
3.
get:
4.
post:
5.
/order:
6.
get
7.
patch
8.
/members
9.
get:
  • A. 1
  • B. 2
  • C. 3
  • D. 5 Most Votes
Correct answer is 5 as APIkit for REST generates a backend flow for each resource-action pairing in a
RAML file.
MuleSOft Doc Ref :
https://docs.mulesoft.com/mule-runtime/4.2/build-application-from-api
A 10 votes
D 11 votes
d.abbas
1 year, 2 months ago
In total, there are 5 APIKit Router components that would be generated to handle requests to every endpoint defined in the RAML specification:
GET /books
POST /books
GET /books/order
PATCH /books/order
GET /books/order/members
acwork
1 year, 1 month ago
I also think that the correct answer's D. one flow for each resource
shxzmk
9 months, 3 weeks ago
There are 5 resources or endpoints. so API KIT generates 5 flows
muchacholindo
2 months, 2 weeks ago
The correct answer is A, because he is asking for "How many APIKit Router components" not how many endpoints
