mcd-level-1 question 176 discussion
back to mulesoft forum
Question 176
What is the correct way to format the decimal 200.1234 as a string to two decimal places?
  • C. 200.1234 as String as format: ".0#"
  • D. 200.1234 as string {format: ".0#"} Most Votes
Correct answer is 200.1234 as String {format: ".0#"} . Rest all options are not syntactically correct.
9%
D 10 votes
90%
galibakravan
11 months ago
A, B option not visible in question.
if Answer is B, then B value should be "200.1234 as String {format: ".0#"}
