mcd-level-1 question 163 discussion
back to mulesoft forum
Question 163
How can you call a subflow from Dataweave?
  • A. Not possible in Mule 4
  • B. Import function
  • C. Lookup function
  • D. Include function
This is a trick question.
You can call only flows from DataWeave using lookup function. Note that lookup function does not
support calling subflows.
A subflow needs a parent context to inherit behaviors from such as exception handling, which a flow
does not need
Hence correct answer is Not possible in Mule 4
A 9 votes
C 8 votes
D 3 votes
pronilofficial
6 months, 2 weeks ago
Subflow cannot be called using lookup function, only flow can be called. So answer is A.
