hpe6-a80 question 49 discussion
View all Aruba Certified Design Expert Written Exam here
back to hp forum
Question 49
A retailer wants to add a wireless network to its stores to provide guest access. The store has wired
POS systems which the customer will now replace with wireless systems.
What is one Important security action that the wireless solution supports to comply with PCI DSS?
  • A. Use test-practice, factory default settings for security settings and login credentials.
  • B. Implement TKIP encryption on the wireless network used by POS devices.
  • C. Impose mandatory clean up periods to delete records of user access to controllers
  • D. Enforce role-based access control on administrators who access controllers
ccossio14
1 year, 3 months ago
can´t use factory default settings as a security
