hpe6-a78 question 8 discussion
View all Aruba Certified Network Security Associate Exam here
back to hp forum
What is a benefit or using network aliases in ArubaOS firewall policies?
  • A. You can associate a reputation score with the network alias to create rules that filler traffic based on reputation rather than IP.
  • B. You can use the aliases to translate client IP addresses to other IP addresses on the other side of the firewall
  • C. You can adjust the IP addresses in the aliases, and the rules using those aliases automatically update
  • D. You can use the aliases to conceal the true IP addresses of servers from potentially untrusted clients.
certexamgo
7 months, 2 weeks ago
C is the correct answer
