hpe6-a78 question 59 discussion
View all Aruba Certified Network Security Associate Exam here
back to hp forum
Question 59
You have been asked to rind logs related to port authentication on an ArubaOS-CX switch for events
logged in the past several hours But. you are having trouble searching through the logs What is one
approach that you can take to find the relevant logs?
  • A. Add the "-C and *-c port-access" options to the "show logging" command.
  • B. Configure a logging Tiller for the "port-access" category, and apply that filter globally.
  • C. Enable debugging for "portaccess" to move the relevant logs to a buffer.
  • D. Specify a logging facility that selects for "port-access" messages.
Pyrokar
8 months, 1 week ago
A is correct
