You are managing an Aruba Mobility Controller (MC). What is a reason for adding a "Log Settings" definition in the ArubaOS Diagnostics > System > Log Settings page?
Configuring the Syslog server settings for the server to which the MC forwards logs for a particular category and level
Configuring the MC to generate logs for a particular event category and level, but only for a specific user or AP.
Configuring a filter that you can apply to a defined Syslog server in order to filter events by subcategory
Configuring the log facility and log format that the MC will use for forwarding logs to all Syslog servers
Pyrokar
8 months, 1 week ago
Answer is B. "Sometimes you might need to log or debug events on a particular user or AP. You can set up this targeted logging in the Diagnostics > Logs > Log Settings page. Click the + icon."
Want to join our community?
Answer is B.
