hpe6-a78 question 5 discussion
View all Aruba Certified Network Security Associate Exam here
back to hp forum
What is a correct guideline for the management protocols that you should use on ArubaOS-Switches?
  • A. Disable Telnet and use TFTP instead.
  • B. Disable SSH and use https instead.
  • C. Disable Telnet and use SSH instead
  • D. Disable HTTPS and use SSH instead
certexamgo
6 months, 3 weeks ago
C is the correct answer
