hpe6-a78 question 48 discussion
View all Aruba Certified Network Security Associate Exam here
back to hp forum
Question 48
Refer to the exhibit, which shows the current network topology.
You are deploying a new wireless solution with an Aruba Mobility Master (MM). Aruba Mobility
Controllers (MCs). and campus APs (CAPs). The solution will Include a WLAN that uses Tunnel for the
forwarding mode and Implements WPA3-Enterprise security
What is a guideline for setting up the vlan for wireless devices connected to the WLAN?
  • A. Assign the WLAN to a single new VLAN which is dedicated to wireless users
  • B. Use wireless user roles to assign the devices to different VLANs in the 100-150 range
  • C. Assign the WLAN to a named VLAN which specified 100-150 as the range of IDs.
  • D. Use wireless user roles to assign the devices to a range of new vlan IDs.
Pyrokar
10 months, 3 weeks ago
Answer is A, one VLAN for tunneled traffic to MC which enforces policies based on roles.
