You need to deploy an Aruba instant AP where users can physically reach It. What are two recommended options for enhancing security for management access to the AP? (Select two )
Disable Its console ports
Place a Tamper Evident Label (TELS) over its console port
Disable the Web Ul.
Configure WPA3-Enterpnse security on the AP
install a CA-signed certificate
B, E
Pyrokar
8 months, 1 week ago
A and B are correct
Want to join our community?
A and B are correct
