hpe6-a78 question 20 discussion
View all Aruba Certified Network Security Associate Exam here
back to hp forum
Question 20
You configure an ArubaOS-Switch to enforce 802.1X authentication with ClearPass Policy Manager
(CPPM) denned as the RADIUS server Clients cannot authenticate You check Aruba ClearPass Access
Tracker and cannot find a record of the authentication attempt.
What are two possible problems that have this symptom? (Select two)
  • A. users are logging in with the wrong usernames and passwords or invalid certificates.
  • B. Clients are configured to use a mismatched EAP method from the one In the CPPM service.
  • C. The RADIUS shared secret does not match between the switch and CPPM.
  • D. CPPM does not have a network device defined for the switch's IP address.
  • E. Clients are not configured to trust the root CA certificate for CPPM's RADIUS/EAP certificate.
A, E
certexamgo
6 months, 3 weeks ago
C, D are the correct answers
