You Just downloaded a logical enclosure support dump, but you cannot extract files from the downloaded support dump. What is a likely cause of the issue?
The support dump for Logical Enclosure can be analyzed only using special tool.
The support dump is encrypted and cannot be unpacked
The support dump does not have a valid HPE OneView certificate
The backup user role must be used to extract the support dump
cassucena
1 year, 7 months ago
B is Correct
Want to join our community?
B is Correct
