hpe2-t37 question 58 discussion
back to hp forum
Question 58
You are creating a Logical Interconnect Group for a three-frame HPE Synergy solution with HPE
Virtual Connect SE100Gb F32 Modules for Synergy.
In which scenario should you set redundancy for master modules to be highly available?
  • A. When storm control or loop protection will be enabled for Virtual Connect modules
  • B. When each of the frames has two Virtual Connect modules installed
  • C. When each Virtual Connect module is installed in different frame
  • D. When each Virtual Connect module is installed in different fabric
0%
0%
cassucena
1 year, 6 months ago
When each Virtual Connect module is installed in different frame -- is the correct
