hpe2-t37 question 31 discussion
back to hp forum
Question 31
Your customer added HPE Primera to HPE OneVlew and enabled volume provisioning on all storage
pools. For security reasons, the customer wants to disable volume provisioning using HPE OneView
on a specific storage pool.
How can this task be completed?
  • A. The storage pool should be removed from HPE OneView using a PowerShell script.
  • B. The storage pool should be disabled using the array management tool.
  • C. The storage pool state should be changed to discovered using HPE OneView.
  • D. The storage pool should be marked as read-only using HPE OneView.
cassucena
1 year, 7 months ago
cassucena
