hpe2-t37 question 25 discussion
back to hp forum
Question 25
Your customer wants to use HPE OneView for VMware vCenter Server to simplify management of
their VMware cluster running on HPE Synergy. The customer is concerned with the cost of additional
licenses.
How will you explain licensing rules for this product?
  • A. As long as the customer has HPE OneVtew Global Dashboard deployed, HPE OneView for VMware vCenter Server does not require any additional licenses.
  • B. One HPE OneView for VMware vCenter Server license is required per HPE Synergy frame if more than 10 Compute Modules are installed in the frame.
  • C. If the number of the HPE Synergy Compute Modules installed in HPE Synergy frame is less than 10, no license is required to use HPE OneView tor VMware vCenter Server.
  • D. As long as the server is managed using HPE OneView. the customer can use HPE OneView for VMware vCenter Server without additional licenses.
cassucena
1 year, 6 months ago
Synergy only has 1 license that customers can purchase, which is the FC connectivity upgrade option for the HPE Virtual Connect SE 100Gb F32 Module for Synergy (FC upgrade SKU's are R3P67AAE and R3P67A). Otherwise, no other features within OneView require a license for Synergy. This does not apply to external resources outside the scope of HPE Synergy (i.e. storage systems).
