hpe2-t37 question 24 discussion
back to hp forum
Question 24
You configured downlink aggregation for one of the HPE Synergy Compute Modules in an
environment by placing two connections in the same Link Aggregation Group. After you made the
changes to the server profile, its status changed to critical.
What can be done to fix this issue?
  • A. The teaming or bonding driver in the server OS must be configured to enable the LACP and to form the LAG correctly.
  • B. The server profile for a given HPE Synergy compute module should be reapplied, then the Compute Module should be rebooted.
  • C. Link Aggregation Group functionality should be enabled in advanced properties of the Logical Interconnect.
  • D. Ensure that the Link Aggregation Group time-out value matches the server set values.
cassucena
1 year, 6 months ago
A is correct -- The teaming or bonding driver in the server OS must be configured to enable the LACP and to form the LAG correctly.
