hpe2-t37 question 22 discussion
back to hp forum
Question 22
You want to update the firmware for only two HPE Synergy Virtual Connect SE 32Gb FC Modules of a
large environment. From which level must this procedure be initiated?
  • A. Logical Enclosure
  • B. Logical Interconnect Group
  • C. Logical Interconnect
  • D. Server Profile
https://cdn.cnetcontent.com/syndication/feeds/hp-ent/inline-
content/S7/C/D/CD7C939EFCECEA1124D03234E6E25BC684192820_source.PDF
cassucena
1 year, 7 months ago
C is correct -- Since the firmware baseline applied on the logical interconnect is 1.4.0, and the replacement VC module is running with firmware 1.3.0, the replacement VC module must update to 1.4.0 to match the firmware baseline of the logical interconnect and to maintain the same firmware versions for both VC modules in the logical interconnect.
