nse7-sdw-7-2 question 51 discussion
View all fortinet nse 7 - sd-wan 7.2 here
back to fortinet forum
Question 51
In which SD-WAN template field can you use a metadata variable?
  • A. You can use metadata variables only to define interface members and the gateway IP.
  • B. Any field identified with a dollar sign (S) in a magnifying glass.
  • C. Any field identified with an "M" in a circle.
  • D. All SD-WAN template fields support metadata variables.
B 3 votes
geroboamo
6 months, 1 week ago
it is definitely B.. SDWAN study guide 7.2 page 47
ha33yp0tt3r69
5 months, 3 weeks ago
Any field identified with a dollar sign ($) in a magnifying glass.
Identification of Fields:
In FortiGate SD-WAN templates, specific fields where metadata variables can be used are marked with an icon that looks like a magnifying glass with a dollar sign ($). This visual cue indicates that you can insert dynamic content into that field.
Using the Dollar Sign ($):
When you type the dollar sign ($) in one of these identified fields, it triggers a menu that displays all the available metadata variables. This allows you to select from pre-defined variables that are relevant to your configuration.
Metadata Variables:
Metadata variables are essentially placeholders that can hold different values based on the context in which they are used. For example, you might have a variable for a subnet, and its value could differ depending on which branch office or site the configuration is being applied to.
