nse7-sdw-7-0 question 39 discussion
View all Fortinet NSE 7 - SD-WAN 7.0 here
back to fortinet forum
Question 39
Refer to the exhibit, which shows the IPsec phase 1 configuration of a spoke.
What must you configure on the IPsec phase 1 configuration for ADVPN to work with SD-WAN?
  • A. You must set ike-version to 1.
  • B. You must enable net-device.
  • C. You must enable auto-discovery-sender.
  • D. You must disable idle-timeout.
B 4 votes
davidjulianbaronwork
1 year, 1 month ago
B net-device. es requerido
geroboamo
7 months, 3 weeks ago
auto-discovery-sender is meant to be configured on hub phase1 towards scopes
