nse7-sdw-7-0 question 30 discussion
View all Fortinet NSE 7 - SD-WAN 7.0 here
back to fortinet forum
Question 30
Which two statements are correct when traffic matches the implicit SD-WAN rule? (Choose two.)
  • A. The sdwan_service_id flag in the session information is 0.
  • B. All SD-WAN rules have the default setting enabled.
  • C. Traffic does not match any of the entries in the policy route table.
  • D. Traffic is load balanced using the algorithm set for the v4-ecmp-mode setting.
ad
A 3 votes
C 3 votes
geroboamo
7 months, 3 weeks ago
v4-ecmp-mode setting is available only if you are not using sdwan
geroboamo
7 months, 2 weeks ago
when traffic is routed according to the default sdwan policy sdwan_service_id is 0 and it is load balanced as per the algorithm chosen in the rule.
answer B doesn't mean anything, and v4-ecmp-mode is used only when sd-wan is not enabled
