nse6-fwf-6-4 question 13 discussion
View all Fortinet NSE 6 - Secure Wireless LAN 6.4 Exam here
back to fortinet forum
You are investigating a wireless performance issue and you are trying to audit the neighboring APs in
the PF environment. You review the Rogue APs widget on the GUI but it is empty, despite the known
presence of other APs.
Which configuration change will allow neighboring APs to be successfully detected?
  • A. Enable Locate WiFi clients when not connected in the relevant AP profiles.
  • B. Enable Monitor channel utilization on the relevant AP profiles.
  • C. Ensure that all allowed channels are enabled for the AP radios.
  • D. Enable Radio resource provisioning on the relevant AP profiles.
The ARRP (Automatic Radio Resource Provisioning) profile improves upon DARRP (Distributed
Automatic Radio Resource Provisioning) by allowing more factors to be considered to optimize
channel selection among FortiAPs. DARRP uses the neighbor APs channels and signal strength
collected from the background scan for channel selection.
https://docs.fortinet.com/document/fortigate/6.4.0/new-features/228374/add-arrp-
profile-for-wireless-controller-6-4-2
D 3 votes
dilou59
3 months, 4 weeks ago
Answer is D
dilou59
Answer is D
