nse6-fwb-6-1 question 30 discussion
View all Fortinet NSE 6 - FortiWeb 6.1 Exam here
back to fortinet forum
Question 30
You are using HTTP content routing on FortiWeb. You want requests for web application A to be
forwarded to a cluster of web servers, which all host the same web application. You want requests
for web application B to be forwarded to a different, single web server.
Which statement about this solution is true?
  • A. The server policy applies the same protection profile to all of its protected web applications.
  • B. You must put the single web server in to a server pool, in order to use it with HTTP content routing.
  • C. You must chain policies so that requests for web application A go to the virtual server for policy A, and requests for web application B go to the virtual server for policy B.
  • D. Static or policy-based routes are not required.
ballhysa
6 months, 3 weeks ago
D is the answer
