nse4-fgt-7-2 question 99 discussion
back to fortinet forum
Question 99
Refer to the exhibits.
An administrator creates a new address object on the root FortiGate (Local-FortiGate) in the security fabric. After synchronization, this object is not available on the downstream FortiGate (ISFW).
What must the administrator do to synchronize the address object?
  • A. Change the csf setting on ISFW (downstream) to set configuration-sync local.
  • B. Change the csf setting on ISFW (downstream) to set authorization-request-type certificate.
  • C. Change the csf setting on both devices to set downstream-access enable.
  • D. Change the csf setting on Local-FortiGate (root) to set fabric-object-unification default.
C 7 votes
D 8 votes
rbo69
1 year, 1 month ago
I guess the correct answer should be: Change the csf setting on ISFW (downstream) to set fabric-object-unification default. Or am I wrong?
semartinez
11 months ago
Configuracion
