nse4-fgt-7-2 question 83 discussion
back to fortinet forum
Question 83
A network administrator wants to set up redundant IPsec VPN tunnels on FortiGate by using two IPsec VPN tunnels and static routes.
All traffic must be routed through the primary tunnel when both tunnels are up. The secondary tunnel must be used only if the primary tunnel goes down. In addition, FortiGate should be able to detect a dead tunnel to speed up tunnel failover.
Which two key configuration changes must the administrator make on FortiGate to meet the requirements? (Choose two.)
  • A. Configure a higher distance on the static route for the primary tunnel, and a lower distance on the static route for the secondary tunnel.
  • B. Configure a lower distance on the static route for the primary tunnel, and a higher distance on the static route for the secondary tunnel.
  • C. Enable Auto-negotiate and Autokey Keep Alive on the phase 2 configuration of both tunnels.
  • D. Enable Dead Peer Detection.
ad
B 8 votes
D 9 votes
javalcasan
11 months, 3 weeks ago
D is OK. But the route of the primary tunnel must have a lower priority than the secondary tunnel, so should it B and not A.
deepz142
8 months, 3 weeks ago
answer is BD
